Samsung galaxy s2x or s2, doesn't get signal etc
  • 6 May 2013
  • 1 reply
  • 10 views
Hi my samsung recently stopped getting text messages, phone calls, voicemails, and doesnt connect to wifi, and it constantly turns on and off and when i try to turn it on it shuts down as soon as i try to enter my password a second time ( after i turn it off again). is this because of koodo, or would it be because my phone is broken and needs repair. i've taken the battery out, the sim card out, restarted it, everything. please help. also my data reset and wont turn on..
Best answer by Sophia 7 May 2013, 00:46
Ack! It almost sounds like there might be something wrong with your battery... it sure does sound like something is wrong with it. When did you get it? If less than 12 months ago, there would still be a warrantee on it and I'd recommend taking it to Koodo to have it repaired.
1 reply
