Samsung Galaxy S11X Charge Will Ya??!!
I have a Samsung Gallaxy SiiX. For the most part it has worked well for the past year. Just lately it kicks in and out of charging mode. I tried a new charger - it's still acting the same. Options?
Is the USB connection lose? Meaning, can you wiggle it around or is it tight? You might want ti try a charger with a longer tip, that's what I did when I had charging problems. Typically a cable from Motorola or HTC have longer tips than others.
It is the phone end. The USB end seems OK. I have to push the charger into the phone, and wiggle it up and sideways to get it to charge. Then it sometimes will charge for a bit.
It is the phone end. The USB end seems OK. I have to push the charger into the phone, and wiggle...Sounds like a charging port issue. As it's probably out of warranty, I suggest taking it to a local repair shop. It should be less than $50 to fix if I recall correctly.
