samsung galaxy note 2 smart phone goes directly to voice mail instead of ringing
(empty)
Try a battery pull out or resetting network settings. To reset network settings, It should be something like Tap Menu >Tap Settings > Tap Wireless and Network > Tap Mobile Networks > Tap Access Point Names >Tap Menu > Tap Reset To Default How long have you had this problem?
the phone is 3 weeks old and it is an intermittent problem. it has full bars and my wife has the same phone with no problem all settings are the same on both phones. she can be right beside me and i call her her phone it rings. she calls me it goes to voice mail. next time it will ring, then go to voice mail . very strange I have tried turning it off pulled the battery removed sim card all with the same results. Very Strange only one phone doing it
the phone is 3 weeks old and it is an intermittent problem. it has full bars and my wife has the ...That is pretty strange, since you still have warranty you can bring it to a koodo kiosk and have them take a look at it.
