samsung galaxy ace wont text (NOT DATA PACKET PROBLEM)
samsung galaxy ace cant recieve or send text but can call both ways..... no it is not the data packet thing..... getting tired of all the problems with this phone and/or koodo.
Hi Hayley, I'm sorry you're having so much trouble.. I don't have a lot of experience dealing with texting issues but is your message centre number +16475800172? (Under the message app, tap menu button, then tap settings and scroll down)
Josh765 wrote:
Hi Hayley, I'm sorry you're having so much trouble.. I don't have a lot of experience dealing...
furthermore you should get rid of unwanted messages in your inbox, increase SMS/MMS limits, check delete old messages and auto-retrieve in your SMS settings, if not working reset your phone settings to factory default settings, regarding your remark on (Not Data Packet Problem) her is a post where it was discussed for Galaxy Ace http://community.koodomobile.com/koodo/topics/samsung_galaxy_ace_not_sending_texts_but_receiving_sending_everything_else
Before performing the reset to factory state, it is better to call Tech support to have your SMS profil checked if it is well set up . Do not forget if the solution is a reset to default settings to backup all your data by using Samsung Kies.
