Samsung galaxy ace 2 x got new one same problems
I had a problem with my samsung galaxy ace 2 X and the wifi decided to stop working, it started with the sound randomly going fuzzy like a blown speaker .So koodo said we will reset your small tab and you can go and get another one at a local store. I did go and get another one, I had already paid 20 off this defectictive phone and I get another Samsung galaxy ace 2 x and the first night the volume made the exact same sound as the first the wifi works for now.....My tab has been reset as i started. My question is what do i do I dont deserve a bad cell phone and btw i barley use and i didnt drop etc. so what do i do stick with the phone and wait and get a better one or ask for my 20 dollars i put into the credit i pid on the earliear bad cell, with this same one starting the same thing
I'd recommend you try another device like the S2X if it's available at the Koodo store near you
Well i have to look it up s2x ...now i kno why everyone walks with an iphone stability
The Ace 2X is an entry-level Android nowehere near the same level as an iPhone. Compare the iPhone to a high-end Android & there won't be the same problems / limitations. The S2X is a solid device in the high range of the mid-level Android devices.
Koodoo cool samsung overrated
I use many phones and Samsung is not over rated by any means, the issue is you bought an entry level device and with smartphones of any brand especially Android you get what you pay for. You buy a device for $150 your going to get the performance as such, you buy a $500-$900 device your going to get what you paid for and a product that has no limitations as far as performance. The only way to pay a couple hindered dollars and get a phone that will perform very well is to buy a high end model from a year or two ago or to buy the Nexus 4. Me and John both use the Nexus 4 & we both highly recommend it & we have many more expensive devices including the Galaxy Note 2, Galaxy S3, Galaxy S4, iPhone 4, iPhone 5, BlackBerry Z10 & more. Go get the Nexus 4 which is only a hundred dollars more than the phone you have & you'll be extremely happy & Never buy any low end phones again other than Nexus devices. Is this "fuzzy" sound when you turn the volume to maximum or close to it?
It's not that samsung is overrated. The ace 2x is a low end phone. I have it and it's not very good at all. I will be replacing it with the nexus 5.
