Samsung Galaxy A50 Wifi Issue
  • 13 June 2019
  • 222 views
Anyone else with this phone having the WiFi "disconnecting" every so often? I haven't changed any of the network settings and this is the only device that's been having issues in the household.
Was it disconnected while the phone was idle.? If so, you could try to turn on the option to keep wifi during sleep. https://www.youtube.com/watch?v=5LwQo2ff614
Nope because it will randomly do it while I'm using my phone. Only loop around I have found so far is to force it to switch over to data.
Have you tried to reset the network settings?
You could also try to forget that wifi network and readd it again.
Yeah I have. Even tried connecting it to my 5G network and still the same issue. If I go out anywhere with WiFi I'll also give it a shot to see if it's my router or something.
I would try it with a different wifi network and see if the wifi stable. You could also try to reset the phone to its default factory and see it resolves the problem (you need to backup all of your data).
By the way, was your wifi properly setup with wpa2 standard or higher security. Some newer phone try to avoid unsecured networks.
