samsung A71 wifi calling
  • 10 October 2020
  • 2 replies
  • 68 views
Hello,
I'm looking at buying a Samsung A71, but since the service in my area is no good, I need to use a device that has wifi calling.  Can I wifi call on this device?
Was your phone purchased from Koodo and you were on a postpaid plan? If so, yes you could enable it following this https://www.koodomobile.com/en/help/wifi-calling
You should be able to use wifi calling on the Samsung A71. Make sure you get the Canadian model (SM-A715W), as it may not work for the international models.
