Samsung A5 2017 - VoLTE
  • 25 November 2018
  • 462 views
Technical support told me twice that VoLTE is working on the Samsung A5 2017 since August 2018. I have Koodo VoLTE Access under Add-ons in Self Serve but it's still not working. My phone is from Koodo. Is there something else I'm missing?
hi,
How did you know it wasn't working? did it switch to 3G when you called? the A5 supports VoLTE but not VoWiFi, as in their specs. I would also suggest you to try to update it to the latest software if there was any.
Is the VoLTE activated on your phone?
Yes it's always going from LTE to 3G when I make or receive a call. Unfortunately I just saw on their help page that the A5 2017 is not listed as VoLTE enabled with Koodo so they probably confused it with the Samsung A8.
https://www.koodomobile.com/help/voLTE
Hi,
I discovered a way to replace some system files to make VoLTE work on the A5 2017. I need VoLTE while on the phone because the Internet is very slow for me in 3G.
There are two files in the folder device/system:
CSCVersion.txt
SW_Configuration.xml
And the files that are under device/system/csc
Can someone with the Samsung A8 from Koodo could please share these files?
I have that phone but where are those files and how do I share them?
Thank you but I already managed to get VoLTE and Wi-Fi Calling working on my A5 2017. It looks like we can't send private messages here.
