Same plan as spouse
I have been a customer with Koodo for over 6 years. I want to get a plan for my wife from Koodo (as a new customer) and I want the same plan for her as I do. Though Koodo doesn't offer that plan currently, is it possible to get that for her by any means (calling them or going to the koodo shop)? Thanks
In a nut shell, no, for new customers you need to pick from the current available plans
You can't get her same plan as Daniel said, but at least you can use Refer-a-Friend Program.
https://referafriend.koodomobile.com/public/home.pg?INTCMP=KMNew_HomeBAN_RAF_LearnMore
And if you add her under your account, then you and your wife have  unlimited talk minutes between you two.
