S5 neo, data works on only MMS, how do I fix
I have the s5 neo, and my data will turn on but won't work on any apps or games. I am able to send MMS's but I have no Internet access to anything else on data
Check selfserve under add ons for a data block. You'll have to remove it if it's there to use data for anything else.
Thankyoufor the help, that fixed it
