Roaming with Samsung
  • 28 October 2014
  • 2 replies
  • 6 views
Then I travel to the US with a roaming add on. I have to reset my phone all the time to get it to work. When I answer the phone with out a reset I can not understand what they are saying. I have a Samsung sgh-t989d
Userlevel 3
Hey Dale, When you say reset, do you mean you have to do a factory reset of the phone? ________________________ If you see a good answer, give it a star.
Yeah the S2x and AT&T dont like eachother. I had the same issue. Only fix is to power it off and remove the battery and sim. Then replace the sim and battery. Weird but thats the way it is.
