Roaming is supposedly disabled...
I have a samsung galaxy s3, and I have already disabled the roaming from the settings. However, it keeps popping up, and trying to get me to pick a location. Has this happened to anyone before, and does anyone know what to do? Because it's really annoying when I'm trying to do something, then whatever I'm doing gets interrupted by the roaming that is supposed to be turned off already.
Try powering off the phone completely, remove the battery and SIM card for a minute or two, reassemble and power the phone back on. Let us know if this fixes the problem.
Maybe try to disable the Location Services? Maybe roaming isnt the problem.
