Roaming Data for More than a month
Canadian travelling in U.S. for 3 mo. Texted 30ALL to get 750 Data, unlimited calls & texts. Went to renew at the end of the month and am told that you can only renew calls and texts, not Data. What??
Hi Jane,
You need to wait for your billing cycle to reset before adding the same add-on again. You can only have 1 of each roaming add-on per period. Wait a couple of days and you should be able to add the same add-on again.
Don't think it has anything to do with the billing cycle because the cycle runs from mid-month to mid-month.  The add-on started at the end of the month.  Anyway, are you saying that once the add-on has expired, that I can definitely get 30ALL (data plus calls/texts) again for the following month?
Jane Hickson wrote:
Don't think it has anything to do with the billing cycle because the cycle runs from mid-month to...
Yes.
Great.  Thanks.  Spoke to a rep at Koodo and he said I could not renew the data, just the calls/texts.  Maybe he was confused.
