Reset phone , will it stay unocked?
I want to reset my Samsung Galaxy Core with a factory reset. The phone is unlocked thru the Koodo unlocking service. If I do the reset, will it stay unlocked?
1 reply
It should. It's possible that if it's a locks to first Sim setup that it'll lock after putting in a Sim card but you should be able to just enter the unlock code again and be fine if it comes to it.
