reset phone
  • 22 October 2013
  • 7 replies
  • 84 views
my son tried to quess my password now its askin for my google email witch i dont rerember n cant get into the phone now any way i could reset it ?
You should be able to do a hard reset (you'll lose the data on your phone - texts, contacts, photos, etc.). What exact phone model is it?
Userlevel 4
Why not go to gmail.com and reset the gmail password? Sometimes that can work and you won't lose anything on the phone.
Why not go to gmail.com and reset the gmail password? Sometimes that can work and you won't lose ...I dont think OP remembers the email :s
Userlevel 4
Why not go to gmail.com and reset the gmail password? Sometimes that can work and you won't lose ...That can be true. It wasn't stated what part of the gmail was forgotten 😛
try default code like 0000 or 1234 to reset it .If it doesn't reset your mobile then visit http://www.unlock-free.com here they provide master reset code for some Nokia DCT phone and Alcatel old mobile models at free of cost using this code you can reset your mobile and again set a new password.
try default code like 0000 or 1234 to reset it .If it doesn't reset your mobile then visit http:...Delicious spam.
