Removing phone calls
  • 27 July 2014
  • 2 replies
  • 20 views
I don't know anything about computers and just purchased a Samsung Ace 11 phone. How do I remove the list of people that have phoned me?
Go into the call logs, press and hold the log and it should give you the option to delete the log one by one. Hope this helps!
Open your Call app. Then sent the "Logs" Tab at the top of the screen. Hit your menu key, and select delete/clear call logs.
