Remote Headphones for Android
Does anyone know of any good earbud headphones that have a control for skipping next track and volume that work well for android phones? specifically an S4?
Userlevel 2
http://lmgtfy.com/?q=Does+anyone+know+of+any+good+earbud+headphones+that+have+a+control+for+skipping+next+track+and+volume+that+work+well+for+android+phones%3F+
I use this on my Nexus 4 but should work any any--> https://play.google.com/store/apps/details?id=com.kober.headsetbutton There's a trial version too if you want to test its functionality on the S4.
it depends on your budget. there are lots of awesome headphones. What's wrong with the headphones that come with the S4, they have all the controls? But a good pair of earbud headphones are the Klipsch S4, but they're a bit expensive. Hope you find a good pair of earbuds! 🙂
