PUK Code
How do I get the PUK code? 😕 my bb broke, so I put my sim card into my moms old phone but it says I need a PUK code so I called them and they said they needed my number so I gave them it and they said it was in-valid so I couldn't get it that way 😕
Call 1-866-995-6636 X6, let rep give you your PUK code to unlock your SIM
Ok, I will try that right now.
same thing happened.
same thing happened.If you tried wrong PUK code more than 10xtimes, unfortunately your SIM got deactivated forever, it's unusable,, you should buy new one.
Userlevel 4
The PUK code didn't work?
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.
Userlevel 4
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.Hmm...so when you call the toll free number you cannot get through? try pressing 0's instead of your phone number. I have received calls from many customers who do not put in a phone number.
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.Not quite sur I understand! did you call 1-866-995-6636 using another line and select option 6?
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.Ok, I will try right now, what information will I need to give you to get the PUK code ? So I can prepare it in advanced.
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.I didn't get an option 6.
Userlevel 4
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.Once the account is verified, all you need to do is mention that your phone is asking for the PUK code. Both tech support and customer service can give you that information.
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.Ok also, Will I need a self serve account? I didn't set one up and I don't think I can because the phones currently not able to receive messages.
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.Any option 5 or 6 will allow to speak with Koodo rep or just press 0, wait for rep, you need to have your account PIN composed of 4 or 6 digit number, if you do not know it they will validate security with your confidential infos on the file
Userlevel 4
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.For what you need, you do not have to have a Self Serve account
They won't give me it, I can't contact support they keep saying my mobile number is in-invalid.I got it, thanks. I just have to call my grandma since she did all the paper work and get her to give me the PIN. Thank you for helping
