Problems sending text to 1 number
Problems sending text to 1 number I have a nexus 5. I'm having problems sending text messages to 1 number which is on Bell iPhone. I am able to receive texts from that number but not send (they don't show up on the other phone) on my Nexus they seem to be sent correctly. I can send texts to other numbers and they go through, it seems to be a problem with this one number. Does anyone have any idea of what I can try? Thanks
If they are marked as sent on your phone that means they are being handed off to the network, which indicates no problem on your phone (assuming you ARE sending to the full 10 digit number). It's probably an issue on the Bell end, but tech support will need to have a look to see if there are any errors affecting the delivery.
This has been resolved, thanks for your help.
