Possible Mute issue on Nexus 4
Userlevel 2
One thing that I've noticed with my Nexus 4 is that when I go into a game app, my music player will stop. When exit the music player, my volume stays disabled unless I reboot my phone. Has anyone else noticed this particular issue and found a resolution for it? And no, I'm not searching for issues 😛. I ❤ my Nexus 4 😃.
What music player are you using Myke? This is different from tapping hard on the screen to see if you can make your buttons rattle slightly because you read it online, your not searching for issues man lol.
Userlevel 2
What music player are you using Myke? This is different from tapping hard on the screen to see ...
Play Music. Now when it mutes, the volume control display actually shrinks and it doesn't move at all.
Have you tried installing a 3rd party music player like "Rocket Player" & seeing if the issue is evident still? If not try it and see if it solves your issue & then you'll know if it's the app or handset software.
