I get this Poco F3 cellphone and i have a problem to send and receive MMS. I tried the problems solution in the community and didn´t solve my problem. I can find help from a Koodo support team member?
Best answer by Dennis
View originalI get this Poco F3 cellphone and i have a problem to send and receive MMS. I tried the problems solution in the community and didn´t solve my problem. I can find help from a Koodo support team member?
View originalDoes data work?
Make sure your APN settings are correct
https://www.koodomobile.com/help/setting-data-your-non-koodo-phone
i have a MIUI phone too and i'm also having this issue (and my APNs are all correct). no idea what causes this or how to fix, maybe it's network side?
Does your regular data work?
Can you post a screen shot of your APN settings?
yes it does! everything but discord voice works (which i have yet to figure out, but it works on my old pixel 2 okay)
Can you post a screenshot of the second portion of your APN settings? (Tap ‘More’).
Please try these settings that I have on my phone. I see the MMSC address is slightly different
