Please i need help badly!
My android is not working properly, i can send mgs to people and they see them but i can't see them from others. I can't figure out what's wrong
Try removing your battery and sim for a few mins and try again
ok thanks ill try that
Pulling the battery.dosnt work at all only works if your android crash but if you got bugs software reset works Wips your phone clean if that won't work. hardware reset this will help you
Userlevel 3
I'm ikaros fan wrote:
Pulling the battery.dosnt work at all only works if your android crash but if you got bugs softwa...
Factory resetting is you last resort! DO NOT TRY FACTORY RESETTING BEFORE YOU HAVE TRIED EVERY OTHER POSSIBLE METHOD:)
