Please help....
Hi, I had bought a sim to fit smsung galaxy s3, but now I am thinking about getting a samsung discover due to budget issues.. Will the same Koodo sim fit it in the discover too, or will i have to go back to the store to change.
According to a list of specs I found it will take a Micro SIM Card which is the same as the Galaxy S3.
If ever you switch to a device with a different sized SIM slot you can switch it back on Self Serve to your previous SIM. Personally I get mine cut & keep the remainder to be used as a "shell" to put inside so I can swap my same SIM between 3 different sizes.
Userlevel 2
John Burke wrote:
If ever you switch to a device with a different sized SIM slot you can switch it back on Self Ser...
If switch between 2 different sim cards, make sure to swap them at least once during a 90 day period so then 1 of the sim cards do not go inactive.
I can confirm that no it will not fit, you need a mini sim ("regular" sized one) which is roughly twice as big as the micro.
Jorden wrote:
I can confirm that no it will not fit, you need a mini sim ("regular" sized one) which is roughly...
I guess the specs I found were wrong, thanks for the correction Jordan. Do you have the discover, how is it?
I don't have it personally, but I've seen a few of them. Not a horrible phone but very very basic. I'd give it the edge over the Ace but not the Ace 2.
