Pixel 3 Wifi Calling
  • 11 January 2019
  • 1102 views
So I had wifi calling on for a few weeks and it was working fine. Yesterday it wasn't on for some reason. So I decided I would turn it off then back on to see if that would fix it. However, now I can't get it to turn on. I get to the last step where you are supposed to hit the finish button after entering the special code and your address but nothing happens.
Anyone have this issue?
Best answer by Goran 11 January 2019, 05:25
Wifi calling isn't officially supported by Koodo yet for the pixel 3.
https://www.koodomobile.com/help/wifi-calling
That could it or its unofficially supported and you can try resetting network settings to see if that'll help as well as restarting your phone.
Hi,
I believed you only have to go to the process of Wifi-Calling activation once. Have you got it On in Settings?
I am just wonder if there were some issues with the local settings. I would try to reset the network settings of the phone if possible.
That page might not be updated. In their Koodo product page of the Pixel 3, Wifi calling was listed as a feature. I think there could be some issue with firmware or some local phone settings. https://www.koodomobile.com/phones/google-pixel-3
It keeps asking me to do the activation every time I turn on wifi calling. I just tried resetting network settings and the same result. VoLTE is still showing on my account so not sure what's up.
It might not be listed but wifi calling is available for pixel 3. As I said, I got them to activate it a few weeks ago and was working fine up until yesterday.
Now I just can't hit the "finish" button on the last step to turn it back on.
Are you able to use VoLTE with the Pixel 3? Also which internet provider are you using ? I would try to set the DNS of the router to google DNS and see if it helps.
