Picture messaging not working on Nexus 5
For some reason, my picture messaging doesn't work. My data is turned on and I have the koodo.sp setting done, as I read in other community forums. Other ideas? I've tried everything I can find...
Did it work before? Try restarting the device.
I've done that multiple times. Hasn't worked in over a week now.
Is your data turned on? Settings Wireless and networks More Mobile network Data Enabled
Yes, data is on, everything else works.
Go into your text messages and delete any messages or conversations you no longer need.
I just did that and still not working.
Are you able to access the Internet with wifi turned off?
Not right now apparently, but I usually can when I'm not on wifi.
It's working now.
*data is working while wifi is off now.
Did you have to change something to get data going?
