Phone says I'm roaming when I'm on EXT
So I got the Rogers Wireless carrier issue solved, but now it's telling me that when I'm on EXT I'm roaming. Is there a reason to this? I don't live THAT close to the American border, so I have no cue why it's telling me that I'm roaming. I don't want to get any fees if I get a phone call or text message.
Best answer by Chad Burr 9 April 2015, 16:34
So you are actually Roaming from Koodo to Rogers or another non telus network when you're using EXT. You won't be charged extra. If you want to use data you'll also need to enable data roaming.
1 reply
