Phone locked with too many pattern attempts
Phone locked with too many pattern attempts. Can Koodo supply a username and password? i don't remember setting this up originally. It's not the same info I use to access the web account.
Koodo can't help you. I see you have an android phone and it's your Google Play store log-in information you need to put it. So the gmail email you used to sign up and password. If you can't remember, unfortunately you'll have to factory reset the phone.
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gmail password as stated by Ahmad. Google your phone model and " hard factory reset " .
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...If Android OS, Press Volume Up and Power Button for 3 seconds until you get Android logo to reset it to Factory default settings.
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...You can't make a blanket statement about how to reset android phones. On the optimus one, it's home plus down volume plus power. On the HTC one V, it's down volume and power, on the optimus chat it's send plus down volume plus power. On the galaxy ace it's home and power. On the s2x it's volume up plus volume down plus power.
Userlevel 4
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...up, up, down down, left, right, left, right, B, A, Start
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...If your phone is made by Konami, yes.
Userlevel 4
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...I have the Contra: Alien edition smartphone
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...I love your Grrrrr...... behaviour Tyler, happy weekend! lol
Userlevel 4
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...You too, Mat. lol
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...@TylerC... That's classic!
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...How do I reset a Koodo LG 400 b phone can't remeber my gmail and password to unlock it
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...Google does not turn up a LG 400 b phone. Does the phone go by another name or model number?
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...Can u find the exact type by the esn?
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...Imei? 013356000746449... On the phone case it's LG 3.0
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...Is that IMEI correct? It says invalid when I tried to look it up http://www.imei.info/ Dial *#06# to see your device IMEI
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...Or in Settings try to find About Phone/Device to find the model number
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...it's a E400 Optimus L3.
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...http://www.hard-reset.com/lg-optimus-l3-e400-hard-reset.html
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gm...you can reset the pattern lock by using the steps mentioned in this article: http://www.what-is.in/howto/reset-android-pattern-after-too-many-wrong-attempts.html
Thanks for the responses. I had to do a factory reset. Luckily, everything (except the apps) were backed up with the Samsung Kies software, so all was restored. Cheers!
