Old $35 koodo plan with data paid only per use. How much is it and for how much?
Hi there, I am on an old Koodo Plan for $35 that doesn't include any automatic data. But it came with the data plan being the one where you paid for how much you used. And I am trying to find out what exactly that was again, but I can't find it anywhere... Does anyone know where I can find this?
Best answer by Jonathan I 24 August 2016, 03:56
Try logging into Self Serve and look under plan details. If it's not in Self Serve then it can get dicey because Koodo has had multiple $35 plans without any data. After that I would contact customer service at 1-866-995-6636 to see if they have better visibility on your account.
1 reply
