Nougat Problems
upgraded my One plus 3 to Nougat and now my data does not work. Any suggestions?
Try pulling out your Sim card and putting it back in and restarting your phone. If that doesn't work check your ApN settings to see if they've been changed since you upgraded.
Same problem here with OnePlus 3T. Pulling the SIM card out and in again did not help, nor did rebooting.
Changed the APN with the settings found on this page and it worked. Thanks Goran.
http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data-on-android/How-do-I-setup-dat...
Thanks!!!!
After adding the settings everything is good.
Glad it worked! Thanks for letting us know it did.
Userlevel 4
Is this nougat upgrade available for the lgg4 and if so is it better than what's on the lgg4 right now thanks
Lloyd Willett wrote:
Is this nougat upgrade available for the lgg4 and if so is it better than what's on the lgg4 righ...
No word on the LG G4 (see link). LG's are not generally the fastest at getting Android updates, but not the slowest, either.
