notification issues
  • 11 September 2013
  • 4 replies
  • 22 views
there is an icon in the left hand corner of my android phone that looks like an i with a crossed off circle around it. i dont get any notifications, text, call or anything
Place your finger on the black status bar at the top of the screen and drag down. Drag the row of green icons at the top of the page to the left. You'll see a notifications icon that's greyed out. Tap on it to turn notifications back on.
thanks
Np. I work in tech support and it took me months to figure out what that icon meant. It isn't documented in the user guide.
Np. I work in tech support and it took me months to figure out what that icon meant. It isn't d...Thanks Timo! Good catch 🙂
