note 2 Samsung 3 and 4
[b]I want to know if you can block unwanted messages and callers on a Samsung note 2 3 and 4 thanks I got the note 2 here it was cheaper then 3 and 4 some 505 area code calling me and annoying me Cops said if android I should be able to block threw settings or down load a call block app thanks
Settings, Call, Call Blocking, Blocked Numbers, Add.
[b]I only got call rejection under it auto reject mode or auto reject list
Tap on auto reject list, create, than you can add numbers you want blocked.
ty
[b]My cousin said I should use MR N umber as well would this not confuse my call rejection?
MR Number that was sorry?
MrNumber is just an app that blocks numbers and does some other things. You can use it if you'd like and it wouldn't get confused.
https://play.google.com/store/apps/details?id=com.mrnumber.blocker&hl=en
[b]thanks I had a guy text me hes a gas oil supervisor and offered me to be on pay roll and send me 200 a week he said I owe nothing and people say he scamming me so who knows and wanted my bank info as well:
Yea I would steer clear of that. If you get a call from a number you don't recognize you can always ignore it. If you pick up the phone and they start off with a suspicious story just hang up as soon as you can.
Glad you have things sorted out!
Thank you::::
I like phone warrior as well:
re the ?s I had such as stylus and what ever else should it all of been in same topic or did I do right by posting in new ones
Yes, posting a new topic is usually the best option, that way you won't flood people's mailbox when the conversation gets going 🙂
