My s2x says not registered and I cant call or text what can I do to get it all back. The battery pull didnt work and I couldnt find anything under settings for it
did you also take out the sim card when you took the battery out? make sure 2g is off did you also do the update to jelly bean? log into self serve as well and make sure your sim card # matches your account. if you have another koodo phone with the same sim card, then try it in that phone too.
Help
Shortcuts
Bold
Ctrl-B or Cmd-B
Italic
Ctrl-I or Cmd-I
Underline
Ctrl-U or Cmd-U
@Mention
@username
Upload image
Maximum file size: 2MB. Allowed image types: .jpg, .png, .gif.
We use cookies to enhance and personalize your experience. If you accept or continue browsing you agree to our cookie policy. Learn more about our cookies.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
