Does anyone know why one text would make it through and not all the others? As well, will these texts come through once I make it back to Canada?
Thanks for any help
Best answer by BobTheElectrician
Texts are usually held on the provider's server for 5-7 days, after which they expire. Try removing the SIM, rebooting without, then re-inserting and re-booting one last time. That should refresh the network connection on your end. Check your network provider and make sure it's on automatic and not manually on a service other than AT&T or T-Mobile. Then try sending yourself a text.
If it still does not work you should then contact Koodo via Facebook or Twitter.
