Not Able To Text When Connected To Wifi
I have a Samsung Galaxy SII X and for some reason when I connect to WiFi I cannot receive text messages, Is there a way to fix this?
I found a thread where someone had the exact reverse problem: couldn't text while using data! It was not the same phone though. http://community.koodomobile.com/koodo/topics/galaxy_ace_not_texting_on_data you [i]could try Ahmad's suggestion: to switch off WiFi and turn it back on... see if that resolves it for you. Hope so 🙂
Hi there The Hobbit... This is weird... I have the same phone and no issues so far... As far as I know this is not a known issue with this device and there are no reports so far about this issue... My recommendation to you is to do a power cycle to see if this solves the issue. You can also inquiry with TECH support to see if they have more info about this or any solution. Is your data on or off when this is happening to you???
