No Data MMS
Make at MMS texting free from any data usage!
MMS wont take away from any data your plan includes or doesn't include. But data cannot be blocked as it needs to use the data network to send MMS. Any MMS messages will just fall under the unlimited texting. Needing to access data to send them is just a limitation of the technology.
Current plans include unlimited text (SMS)and picture messaging (MMS) but you still need to have data on (you can make sure to keep data charges down by turning off automatic updates (or set your phone to update over wifi only)
