Nexus5 all of a sudden cannot get a data connection
  • 25 March 2015
  • 1 reply
  • 380 views
Switched from Nexus4 to Nexus5 about a week ago. Worked like a charm for a few days, then no data connection. Called Koodo, they did some stuff on the backend and worked for a few hrs, then again same thing happened. Called again, they did some stuff, nothing. Tried the SIM back in the older Nexus4, works fine, so def not a SIM issue. APN settings looks fine, and I've tried both LTE and 3G with no results. Any help will be VERY appreciated.
Best answer by Chad Burr 25 March 2015, 21:18
Is data enabled?
Settings
Wireless and networks... More...data enabled
Also. Are you powering down before removing the sim? If not you should be.
Try power cycling the device too Where did you get this nexus 5?
1 reply
Is data enabled?
Settings
