Nexus S wont connect to Data Networks
So recently my Nexus S has stopped connecting to data networks. That's to say that I can text make phone calls but the phone never has data access unless it's by wifi. I've done the usual trouble shooting. Made sure 2g only option wasn't selected etc. I've resset the phone as well with no luck. Any ideas?
Are the apn's configured right? switch2koodo.com
Is the "Use Packet Data" option selected? Did you try to remove the battery without turning the phone off? Did you make sure there isnt a data block on your account? Try these things out, if it still doesnt work you may have to visit a Koodo Retail Shop. Good Luck 🙂
It was the APN. I didn't have a Koodo APN just a Telus one. Re-entered it and now I'm good. thanks!
How did you enter the APN, my phone has the same problem
the instructions are at switch2koodo.com, step 3.
