Nexus 6 Plan options!!!
If I buy a Nexus 6 from Google Play can I set it up with a lightweight Canada wide plan or only a prepaid plan. I'm not totally sure how prepaid works but I'm too impatient to wait for Koodo to get the 6.
You can set it up with whatever you want. The only time there is a requirement is if your getting it on the tab, in which case you have to meet the requirements for any of the tab levels. If your buying it from google, you can do it on postpaid or prepaid, its all up to you.
Hello Owen, When you mention "lightweight Canada wide plan," is this the current data rate plan you are on? Normally with Nexus smartphones, they are pre-unlocked, this means you can use whichever service you choose. Either prepaid or postpaid will work with the Nexus 6.
Remember if you go with postpaid you will get the 10% discount!
What's the 10% discount?
Userlevel 3
10% off your monthly bill
Yeah its what I'm on right now. I just wanted to make sure I wouldn't have to switch plans.
