Nexus 5 static looking screen. Less than 1 year old
My nexus 5 has a static like screen that wont change no matter what. It's less than 1 year old and i'm wondering if theres a solution to it
Best answer by Jonathan I 9 May 2015, 21:31
As long as it's not physical/water damage, it's covered under warranty. Take it to your local Koodo store for servicing. Backup anything important to you first, as it will be factory reset when it's sent out.
1 reply
