Nexus 5 not registering to Koodo
My Nexus 5 which I got brand new is not connecting to Koodo at all. It happened randomly and all of a sudden, "it says cannot register on this network please try again later" The sim card though works on other phones. I have restarted and done everything, what else can I do?
Userlevel 3
Unplug the battery and sim card from the phone. Also, if this doesn't work you have 14 day money back guarentee. So I would suggest bringing the phone back to the store if this troubleshooting step doesn't work. The store will replacement the phone for you (same model) at no cost.
Rocky Balboa wrote:
Unplug the battery and sim card from the phone. Also, if this doesn't work you have 14 day money ...
The Nexus 5 doesn't have a removable battery man 😉
Check your setting make ssure your network selection isn't set to "Use GSM only", or "Use 2g only"
