Nexus 5 loose power/volume buttons
does any one have a NEXUS 5, i heard that some people are having issues with loose power/volume buttons on the device that shake/rattle when you tap the screen or just pick it up in your hand ?? does any one have these issues, are the buttons on the device loose, there suppose to be firm and in place.
No problems on my end. All buttons are solid.
No loose buttons here either. I keep seeing ppl ramming their Nexus 5's into those dual layer cases without taking the pieces apart and putting on a layer at a time. I'm thinking they're damaging their buttons and then complaining about it. There's a flat edge on the N5 buttons they're not rounded like other phones so you should be more careful when putting a case on or off of it. Like I said though I have no issues and mine only rattle the very slightest (can barely hear) when I shake the crap out of the entire phone, like I mean go nuts on the thing but it's a very solid device.
are u guys using the 16 or the 32 gb model
I'm using the 16gb version and a one of my buddies also has a 16gb version & few of my buddies have the 32gb version and none of us have any issues such as this.
oh ok, thanks.
32 Gig.
