Nexus 5 dialer problem
I have a problem with my dialer as the calls log, contacts and favorites don't get displayed..... It displays a white screen....!! Sometimes it displays correctly......what to do? Any advice?
Sounds like you need to do a factory reset.
Unless someone else can suggest a different fix?
Normally if you develop a software bug over time it is best fixed with a reset.
Thanks, will this affect any of my stored contacts, photos....etc? I presume not as they are on gmail cloud...is that right?
Hossam wrote:
Thanks, will this affect any of my stored contacts, photos....etc? I presume not as they are on g...
If you are certain that everything is backed up to your google account then no you wont lose anything
But I'd recommend doube checking to be safe 😉
Thanks Mitchell
