Nexus 4 problems
Hey, I am using nexus 4 it is under warranty some time volume button is not working, and the battery life is bad with data on it works for 5 hrs only. What can be the option for replacement
Best answer by John Burke 23 May 2014, 19:44
For battery life, is that 5hrs with the screen on or off? If on, that's considered quite good. If off...well yeah, that's pretty bad. A possible problem is Google is having a problem syncing. Go to Settings-> Accounts-> Google then see if there's a red icon indicating something isn't sync'ed properly & try to resync whichever that is.
1 reply
