Nexus 4 making odd sound when I move the phone
It started about a month ago that whenever I tilt my phone it will make a very odd sound. I haven't installed any new apps since and the noise is random. I was told to turn off the screen lock sound which that didn't make any difference. The sound happens at different times. I bought the phone about 6 months ago, should I bring it in for warranty? Thanks
Odd sound? Like from the phone as in a notification type of sound or something mechanical/physical?
It's more of a mechanical noise. I have to shake the phone to get it to stop. It's really hard to describe without hearing it.
Problem solved it was the NFC feature that was turned on and I had my credit cards in the same holder so it was scanning for the rfid signal.
