nexus 4 flash player
How do I install a flash player to view TV on the nexus 4
You'll have to side load it since it was taken out of native Android after 4.0 and even then it might not work properly. Search for Flash .apk online
Jonathan I wrote:
You'll have to side load it since it was taken out of native Android after 4.0 and even then it m...
Make sure that you use the 4.4 specific version (To use with 4.4 it's not the Adobe release version) as its been tweaked from the last version ever released by Adobe and keep in mind it will only work with Dolphin Browser all the others eliminated it being used with their browser completely. You may also have to download the Dolphin Jet pack companion app from the Playstore. If you get the right version of Adobe Flash Player (version specific for 4.4 and above) it actually works very stable but stops and replays the first couple seconds of the video you just watched when starting a video.
