Need to switch to Android, HELP!
  • 4 October 2014
  • 3 replies
  • 10 views
I currently have an iphone 5 through koodo and the battery on it sucks, and it randomly shuts off. I know it isn't koodo's fault, but apple won't get back to me about anything. Is there anything you guys could do to help me switch over to android for low cost? I'm in university and money is pretty tight. If not I understand. Thanks
You can get a phone on the Tab, but you'd have to pay off your current Tab first so that might not be an option... Look into buying an unlocked Moto G. They are dirt cheap now, very decent phone and awesome battery life!
Hi Ben, The only thing I can suggest if you're going to switch from an iPhone to an android device is you can pay off your tab and you can start a new one. There are plenty of Android phones that Koodo offers and they are reasonably priced, it just depends on how much you can afford. The two phones I'd recommend are the Nexus 5 and the Moto G, they're both great performing phones and a lot of people tend to like them. Hope that helps 🙂
Aldo here's the guide I used to switch from ios to android http://gizmodo.com/5944650/how-to-make-the-switch-from-ios-to-android
