Need to reset APN daily to maintain mobile data
  • 22 October 2020
  • 3 replies
  • 77 views
For the last month or so, I have had to reset my APN 1-2x daily to get mobile data. By reset - I mean: changing to a different APN for a minute or two, and then switching back to the Koodo APN in the list. I still stay connected to the mobile network (can make and recieve calls & SMS) - just lose data usage ability.
Phone: OnePlus 6 running Android Oxygen OS
I have tried the following steps to resolve without success:
- Network Settings reset (Settings->system->reset options → reset wi-fi, mobile & bluetooth)
- Moving the sim card between slot 1 & 2
-Phone reboots, turning mobile data on/off, etc.
-problem was NOT preceded by an OS update (started in Sept - previous update was in July). An update in October has not changed the problem.
My next thought is a Sim card replacement. Any other thoughts on what to do here?
Did you check the post-reset network setup against the following (or similar) in Koodo’s network setup web section?
Field
Info
Name
APN
sp.koodo.com
Proxy
Blank
Port
Blank
Username
Blank
Password
Blank
Server
Blank
MMSC
http://aliasredirect.net/proxy/koodo/mmsc
MMSC proxy
74.49.0.18
MMS port
80
MCC
302
MNC
220
Authentication type
Blank
APN type
Blank
It seems Oneplus Oxygen had some glitch with APN settings. Normally the phone should be able to refresh/update the APN from Koodo server.
Anyway, can you try to change your phone APN similarly to this thread
 The OP reported the new APN worked fine for that Oneplus device.
Did you try any of the above noted suggestions? Did it solve the need to reset the APN repeatedly?
If it didn’t, it may be helpful to search for users similar experience with Oneplus’s  Oxygen anomalies with APN settings.
