need help with data
I have a samsung ace2x and i just turned on my data for the first time, but its not working. I cannot download a picture text and cannot connect to google maps or anything internet. How can i fix this? please help
Hi Michelle, Follow the instructions on the following link to set-up access to Koodo's data on your cell phone: http://help.koodomobile.com/plans-add-ons-data-and-other-services/data-basics/how-do-i-setup-data-on-my-non-koodo-phone Hope this helps!
Mathieu wrote:
Hi Michelle, Follow the instructions on the following link to set-up access to Koodo's data on...
I did this and it wont let me click on anything, no save nothing. and everything looks like it does on the chart but still unable to use data
Turn the phone off, remove the battery, remove the sim card. Let it sit for 2 minutes, re-assemble the phone and turn it on, see if that works
ok it works now thank you so much
