NEED A TECH IMEDIETLY!!!
i just had to get a new sim card for my phone today and loose everything!!!! IT just happend 3 hours ago again!!! WILL A TECH PLEASE WRITE ME BACK ASAP!!
Why did you have to get a new sim card and what did you lose? What device are you using? Ps: I don't work for Koodo and I'm not affiliated with them.
Yes lost contact if you backed you information to goolge yeah here the thing goolge hade iso problem
os everything was lost even i hade troubles sending email
I hope this helpful?
Did your phone do a reset or did you just loose your contacts?
If the device was properly backed up, you should be able to restore everything. Contacts shouldn't be dependent on your SIM. I also don't understand why you had trouble sending emails....
Peter wrote:
If the device was properly backed up, you should be able to restore everything. Contacts shouldn'...
Some people do save contacts to their sim. You can store about 200 phone numbers of contacts.
Try a SIM card manager app. https://play.google.com/store/apps/details?id=com.tiennt.android.simcardmgr
