Need a new phone, will tab work with current plan?
  • 21 June 2015
  • 4 replies
  • 30 views
Userlevel 2
I am on the $73 3gb unlimited minutes plan here in alberta. can i go to a tab with this plan? I need a new phone after my note 2 died earlier tonight. I dont see the note 2 on the website anymore but if I cannot get than than the Galaxy s4 on a tab would be my next option...
Yes, you can. If you want to have the S4 on the tab, you can get it $0 upfront plus $15 /mo for next 24 month. So your monthly bill will be $73 plan + $15 phone tab charge = $88 ( plus tax and overage if any) You can reduce monthly tab charge if you put some money on upfront.
Userlevel 2
thanks. I may have to downgrade to the $70 plan...
thanks. I may have to downgrade to the $70 plan...I checked Alberta plan, but I cant find $70 plan...?
Userlevel 2
thanks. I may have to downgrade to the $70 plan...it may not be available any more. there is a $63 one that seems similar to what i have. i will miss the extra 1GB of data but oh well.
